Автор Тема: Обновление штатной навигации на HDD GEN6 (08HDD)  (Прочитано 4107438 раз)
0 Пользователей и 675 Гостей просматривают эту тему.
Оффлайн Tikimarkov
  • Авто: Prius V3
Hi all and thanks for all the excellent instructions and effort. I'm writing from Finland, so I hope it's ok write in English.
I've followed the instructions and managed to update all the files on my B9016 system (Prius 3rd gen 2011). I've tried a few different versions already and have two issues:
1. All the BMP files seem to be unreadable --> all icons are corrupt in the player UI and not readable in Windows either - is this normal?
2. The more severe issue is that when I want to navigate somewhere by pressing Navi -> Address. The system just reboots. The maps seem to have updated but I can't plan any route.
3. The reverse camera is working, however the beep that indicates that the sensors detect and obstacle, is also corrupt (weird distorted hissing sound)
Have I missed something here or has anyone a clue what might have gone wrong? I've updated using the HDAT2 method by copying over the PRG folder, SD folder, updated CDDB and map data.
Since there are problems on multiple fronts, I'm suspecting an issue with the software version in general. Maybe some compatibility issue since I'm updating from a 2011 version. Maybe I should try an older version first? Any ideas would be appreciated and feel free to answer in Russian. Thanks!
Оффлайн illia
    • mapcar@mail.ru
  • -> Вы поблагодарили: 45
  • -> Вас поблагодарили: 221
1. Watch the video from my channel at this link (watch with subtitles if need)
2. Delete (not format, namely delete) the data from the 1st partition and the Prg and Sd folder from the 3rd partition.
And write the data of the 1st and 3rd partions (Folder...map and soft), from this post http://prius-club.su/index.php/topic,1569.msg103055.html#msg103055
3. If you also have problems, you will need to overwrite the hdd image completely.
But first, follow my instructions and telling results!
« Последнее редактирование: 26 Сен. 2019, 00:02:02 от illia »
to Tikimarkov
Hello, friendly Finland!))))
Ohhh, don't worry.
They're frequent problems.
Everything will work out
You probably made one of the following errors:
1 - downloaded files with errors
2 - copied files with errors to the HDD
3- didn't  disconnect the power cord from the receiver
It makes no difference which version is being updated.
If everything is done correctly, then everything will work out.
Sincerely!!!
Илья, зачем опять здесь ваша реклама?
Есть же чистый релиз. Без рекламы.
There is a clean release. 2019-2020 ver.1
No ads.
http://prius-club.su/index.php/topic,1569.5475/msg,122318.html
Оффлайн illia
    • mapcar@mail.ru
No ads.
Сергей, почему такое предвзятое отношение и к чему негодование? ??? Там нет рекламы моей. На фото даже показано что специально для форума релиз.
Я являюсь участником форума ровно также как и вы, и если даю совет кому либо какой-то, то как минимум отвечаю за свои же слова и должен быть уверен в том что советую. Вот как раз в данных на которые я позволил себе сослаться - в них я уверен на 100%. И это понятно по контексту написанного сообщения.
Если ему, такому же участнику форума, с другой страны, не понравится мой совет и рекомендации он может на свое усмотрение воспользоваться другими советами, например вашей информацией, если вы считаете что ваш совет более правильный, либо же информацией изложенной в этой теме.
А вообще не понимаю сути упрека, если по честному!
Если вы правильно поняли, я про рекламу в файлах.
ее там нет?
Оффлайн illia
    • mapcar@mail.ru
ее там нет?
В распакованных файлах для записи на хдд, конкретно этого релиза - нет. Только то, что указано на фото в описании поста.
Оффлайн Tikimarkov
  • Авто: Prius V3
to Tikimarkov
Ohhh, don't worry.
Sincerely!!!
Thanks Illia and Nester! You were spot on here, I didn't unplug the device from the vehicle as I put the updated HDD back in. So that's apparently a key step as well. I didn't remove the device as the radio etc. work just fine without the hard disk.
Anyway, I'm all good now and everything is fine and dandy. Cheers from your neighbor!
Super!  Hienoa! ;D
I'm really glad that everything turned out! ;)
Оффлайн zlt
  • Авто: TLC200, RX450h
  • -> Вас поблагодарили: 25
Для особо непонятливого еще раз: http://prius-club.su/index.php/topic,1569.msg103491.html#msg103491
Оффлайн illia
    • mapcar@mail.ru
Не переходите на личности!
Какое это отношение имеет к сути ситуации?
Релиз не рабочий что ли был? - так чего ж столько благодарных пользователей отметилось под постом?! Или просто не терпежка вылить очередную порцию черноты на другого человека?
Или проще не участвовать вовсе в ответах и помощи другим пользователям, взяв пример с вас и вести только осуждение кого-то и чего-то, освоив N-й дан по диванной экспертизе?!
Была ситуация, она решена уже - пользователь отписал в чём проблема была и поблагодарил всех отозвавшимся в решении его проблемы. Чего влазить теперь?! Вот же ж неймётся :)
Оффлайн Mikem
  • Авто: Tlc200
Что-то у меня винчестер пропал..... :-\
Это из-за чего интересно?
В этом меню он будет не активен, пока вы туда музон не запишите.
Как впрочем и с остальными вкладками. Они не активны до тех пор пока не задействованы хотя бы раз. ))))
AUX гляжу тоже пропал  ;D
Оффлайн Mikem
  • Авто: Tlc200
Музон там уже был до того как....
и записать не дает :'(
Чёто косяк значит.
Переделайте заново.
А все остально работает? нави?
